Old 12-07-2020, 09:46 PM   #1
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
Default CTS trailer problem
Posting to see if anyone else has had trouble with this brand of trailer.
Dealer try's to help but sends us back to manufacture for warrenty
They won't stand by it .Said we over loaded it. "stocker 69 Camaro
and gas golf cart" in a 10k rated trailer Don't think that is over loading
Problem is the tongue A-frame is cracked at the point where
frame and box meet. We have less than 12 trips of 70-300 mi
max. The second photo is flipped 90* Both cracks are across
the top of the tubing
Never buy a CTS brand again
ID:	56454   Click image for larger version
Willyracer is offline   Reply With Quote
Old 12-07-2020, 10:44 PM   #2
Default Re: CTS trailer problem
Ray Charles coulda seen that coming.
That is NOT the way to attach a tongue to a trailer frame.
Old 12-08-2020, 01:30 AM   #3
Dan 1525
Liked 63 Times in 14 Posts
Nasty looking. I had a problem with some of the welds on the frame and the tongue once with my ATC (aluminum trailer) it also had to go back to the Manufacture.5 year warranty they came and got it fixed it and extended the warranty from date of repair they also returned to me, at NO COST. Great trailer, Great People to work with. Yes I would buy another ATC trailer they stand behind there product !!!!!!! Dan Lynch H/SA 1525
Dan 1525 is offline   Reply With Quote
Old 12-08-2020, 02:51 AM   #4
GTX JOHN
Liked 2,487 Times in 698 Posts
You need to run a wrap around tongue going back to front axle hanger even
on a 7000 steel open trailer!! (WE have built trailers for 30+ years}.
Especially on a Aluminum trailer!
They are fragile enough if under rough treatment!
Unbelievable!!!!
John Irving
741 Stock
741 Super Stock
Old 12-08-2020, 08:09 AM   #5
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Sad that a company won't stand behind their products. Looks like you might have to "LEGAL UP" . Sometimes, all that's needed is a letter from an attorney.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 12-08-2020, 08:18 AM   #6
Liked 10,769 Times in 2,238 Posts
Just for fun show those pictures to the local trades school instructor. His opinion will give you something to talk about if it leads a legal discussion.
Old 12-08-2020, 08:44 AM   #7
Ralph A Powell
Liked 225 Times in 136 Posts
Had the same type problem on a Featherlite 15 years ago it cracked were the tounge was welded to main rails right along the weld the cracked across the floor trailer dam near cracked in half. I was at the IRL RACE in Phoenix. They had their service team there but didn’t have a big enough welder so they called one in and patched it up enough to get it back to their factory in Iowa were they completely rebuilt the front section. I had bought a new one and was setting at home in my shop. When I got home we jacked it up and it was welded the same way. Featherlite sent someone to get it took it back to factory in Iowa and completely redone the tounge to frame welding and reinforcement and returned it back to my shop. The problem was when they welded it the first time it caused a stress riser right along the frame were the weld was.
Old 12-08-2020, 11:02 AM   #8
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Not only a bad design also some really bad looking welds.
Mike Pearson 2485 SS
Old 12-08-2020, 11:23 AM   #9
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Must be a lot of that going on. I saw an ATC (24ft ?) on I-85, just south of Charlotte, in the middle of the highway, missing the tongue. It was hanging off the back of a duality, on the shoulder 100 ft away, a few weeks ago.
2894 STK
Old 12-08-2020, 11:56 AM   #10
SSDiv6
Not enough weld penetration and this type of joint needs to be reinforced.
Those welds may be good for a living room table, but not for a high load structural joint.
Find a certified welding inspector and pay them a few bucks for a letter. Then have a lawyer send them a letter and attach the report with a statement that you will be also filing a report with the National Highway Traffic Safety Administration (NHTSA) for the defective welds and request a recall.
I promise you they will either fix it properly or give you a new trailer. They would not like to have the NHTSA pay them a visit, shut them down and fine them.
