Old 11-05-2020, 06:53 AM   #1
JeffM
Liked 5 Times in 5 Posts
Default LS/LSX parts
2 LS7 blocks (3000.00 each)
Up to 4.200 bore.
Include
Dry sleeve liners from LA Sleeve
Jesel .842 lifter bushings.
Custom structural upgrades
Holley fuel rails pn 534-203 new $100.00
Cometic LS7 head gaskets (New/pr) 4.200 bore .056 PN H2462spb056s $120.00
Cometic LS7 head gaskets (New/pr) 4.200 bore .053 PN H2462spb053s $120.00
Cometic LS7 head gaskets (New/pr) 4.200 bore .060 PN H2462spb060s $120.00
3 Pair - Fel Pro LS7 headgaskets (New/Pr)4.200 bore .053 PN 26473L053 and 26473R053 $135/pr
2 Pair - Fel Pro LS7 headgaskets (New/Pr) 4.200 bore .061 PN 22670L-061 and 22670R-061 $175/pr
Single Fel Pro LS7 headgasket (New) 4.200 bore .053 PN 26473L053 $70
Pac valve spring locators 1.270 x .640 x .520 x .060 PN PAC-S121 (dyno test only) set of 16 - $30.00
Pac valve spring locators 1.270 x .600 x .520 x .060 PN PAC-S128 (new open box) set of 16 - $45.00
Pac valve spring locators 1.270 x .615 x .575 PN PAC-S138 New set of 16 $175.00
Pac Titanium retainers 1.200 x .890 x 600 PN PAC-R532 (dyno test only) set of 16 - $250.00
Pac Titanium retainers 1.200 x .890 x 600 PN PAC-R432 (new open box) set of 16 - $170.00
Pac Tool steel retainers 1.250 x .890 x .600 PN PAC-R632 New set of 16 $260.00
Pac valve spring locks 8mm Mini8 +.050 PN L8142 new set of 16 $55.00
Pac titanium valve spring locks 5/16 Mini8 STD PN L8139 new set of 16 $125.00
Pac titanium valve spring locks 5/16 Mini8 +.050 PN L8123 new set of 16 $125.00
Pac titanium valve spring locks 5/16 Mini8 +.050 PN L8124 new set of 16 $125.00
Pac dual valve springs PN PAC-1237X – (dyno test only) set of 16 $225.00
Pac dual valve springs PN PAC-1238X – (dyno test only) set of 16 $225.00
Pac dual valve springs PN PAC-1335 – (new) set of 16
Manley 221443P-16 valve springs with 23648-16 Ti - retainers, locks and 42573-16 locators (run on dyno) $500 for set.
ATI balancer pulley PN 916794 4 groove aluminum 6.430 diameter - New $40.00
ATI balancer pulley PN 916732 4 groove aluminum 6.430 diameter – used $50.00
Meziere WN0032S – 1.50 diam water neck fitting black – $10.00
Callies Compstar 6.100 LS rods with ARP 2000 bolts (used/good) $250.00
Callies Compstar 6.100 LS rods with ARP 2000 bolts (dyno test only) $500.00
CV products 3/8 pushrods (qty 18) 9.200 x .080 x 5/16 ends – used but good condition – $30.00
Trend 3/8 pushrods (qty 16) 7.450 x .135 x 5/16 ends – used but good condition) $50
Trend 7/16 tapered pushrods (qty 16) 9.450 x .165 x 5/16 ends new - $100
Trend 7/16 tapered pushrods (qty 16) 9.400 x .165 x 5/16 ends new - $100
Trend 3/8 pushrods (qty 8) 9.400 x .135 x 5/16 ends used - $25
Trend 3/8 pushrods (qty 8) 9.450 x .135 x 5/16 ends used - $25
Trend (qty 17) – 9.200 DBL taper .135 wall pushrods 5/16 ends (used good) $35
Trend (qty 17) – 9.150 DBL taper .135 wall pushrods 5/16 ends (used good) $35
Trend 9.400 DBL taper .135 wall pushrods 5/16 ends (11) new $100
Trend 9.300 DBL taper .135 wall pushrods 5/16 ends (11) new $100
PAC-12x2.5x90 suspension springs – NEW (pair) $100
PAC-14x2.5x150 suspension springs – NEW (pair) $100
PAC-14x2.5x100 suspension springs – Used (pair) $50
JRI 2010-2015 Camaro front struts $1000.00 used. Will include choice of:
Single LS7 cylinder head complete. Still in Cosmoline. 12578452 casting number – Factory CNC ported with valves, springs, and lashcaps. $1650.00. I don’t believe this head has ever been ran.
LS7 cylinder heads (pair) – unported, has guides and seats. No valves or springs, etc 12578452 – New never used $2200.00
1 LS7/LSX cylinder head casting number GM19166977 – New never ported has seats and guides installed $1900
DR intake manifold base by CFE - $2000.00
2 – Lingenfelter billet steel LS block girdles, No hardware – girdles only $500
JESEL – Sportsman series 1.9 rockers for GM LSX DR cylinder heads set complete with stands $900.00
JESEL – 8 – Sportsman series 1.9 intake rockers (rockers only) $300.00
2 GM truck oil pans (1999-2006) pan only $75.00 each
email superstock@live.com for any questions
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
