Old 11-04-2020, 11:07 PM   #1
dlv4540
Liked 2 Times in 1 Post
Default 396 BBC Parts
1970 396 4 bolt block CKO code ..030 over 3969854 dated I-22-9 cleaned and magged $2000
1969 4346 Holley restored and recolored carb dated 952 $1250
402 standard bore pistons and rods 10.25 to 1 compression also good to use for a .030 396 application $200
8 inch timing cover cleaned and painted with teeth design $125
Crane Roller Rockers iwth UU440 stamped in them. Never used older set laying around but have some slight pitting on them $75
BBC oil bypass mainly used in marine applications $20
330-770-2517 for any questions and can ship if you cannot pick up.
dlv4540 is offline   Reply With Quote
