Old 10-25-2020, 08:03 PM   #1
rick winchester
Liked 208 Times in 35 Posts
Default 231 v6 trans
What transmission are the guys using on the 231 firebirds in stock ? Rick .
Rick Winchester Stk 3277
rick winchester is offline   Reply With Quote
Old 10-25-2020, 08:22 PM   #2
Default Re: 231 v6 trans
I would suspect a TH 200 Metric.The 4 speed automatics are big, heavy, and suck up HP that the V6 doesn't have.
A legal "clutch assisted" 5 speed would probably run well.
Old 10-25-2020, 08:32 PM   #3
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
I know the one of Chin Racing has a M200. Although likely scarce as hens teeth they were made with a 60 degree v6 bellhousing for the early 3rd gen camaros.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 10-25-2020, 10:58 PM   #4
Rick, Chipper is correct. The Doolittle/ Wong/ Chin/ ??? convertible had a McClay 200 in it, when it passed through my shop. It was the GM FWD bolt pattern case.
Could have been from a Camaro, but the 1st gen . S 10 also had the that style behind the 2.8 and the 2.5 engines..Might be a little easier to find.
Old 10-26-2020, 09:58 AM   #5
rick winchester
Thanks guys, saw one for sale real cheap. Thought it would make a low dollar stocker /bracket car for 12yr old grandson to learn on. Rick
Old 10-26-2020, 10:43 AM   #6
rx dealer
Liked 53 Times in 13 Posts
The 231 is a Buick engine and it's a 90 degree V6. The 2.8 in the S-10 is a 60 degree V-6 and it's completely differrent.
rx dealer is offline   Reply With Quote
Old 10-26-2020, 12:13 PM   #7
That it is..but all Buick 90 degree V6's that were also used in FWD cars, had the GM FWD bell housing pattern..and that includes the 3800 Series III that was used in the Firebird /Camaro.
Old 10-26-2020, 12:17 PM   #8
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Later in the development of the 3.8 L Buick they changed the Bellhousing style to the GM small bell configuration . The Buick V-6 used to have the BOP bell , but when that engine was re-done to the Buick 3800 the bell was changed to the GM small bell , so the block was different and was used even in RWD vehicles like the 4th gen Firebirds and Camaros with that small bell . My street car is a 1996 Firebird with a 3800 and it has a 4L60e with that small bellhousing . The small bell was used on the Chevy 2.8 , 3.1 , and 3.4 L engines .
Old 10-26-2020, 04:46 PM   #9
Chris Hill
Liked 244 Times in 26 Posts
You need the C10 pickup for your grandson.
Chris Hill
