Old 10-13-2020, 11:56 PM   #1
bert powell
Liked 34 Times in 12 Posts
Default Turbo Action Shifter with ACD cylinder
I have Turbo Action shifter removed to add clean neutral shifter. Is currently setup reverse pattern for TH350/400. Have two other gates- appear to both be GM, one reverse 3 speed one standard pattern 4 speed. Comes with plastic cover, neutral safety switch, cable and air cylinder from ACD mounted. All you need for air shifting is the ACD control box. Have pictures can text and can bring to Rockingham. $225
bert powell is offline   Reply With Quote
