Old 10-04-2020, 05:40 PM   #1
jamie2370
Liked 239 Times in 90 Posts
Default fuel pressure question
H/SA 350 sbc with quadrajet(Deano carb). Car has a Magnafuel Prostart 500 fuel pump(rated 26-38psi) 12an line to front, Product Engineering Regulator rated 4-12 psi. I am pretty sure that the carb is letting fuel by the needle and seat. It is very rich, sometimes floods out, but then other times at an idle it is perfect. I can not get pressure to go below 6 psi. What is too much pressure for that carb? I know the pump is overkill but it was on the car when I got it. I tried a barry grant regulator that I took off a holley black pump system that was set at 7 psi, it went over 12 psi when I turned the pump on?? SO... do I have a carb issue, too much fuel pressure, or Both lol
jamie2370 is offline   Reply With Quote
