Old 09-29-2020, 09:01 PM   #1
Mgc340
Default ISO Small blocks Mopar x and R blocks
Looking for new or used Mopar small block X blocks or R, R1, R3 race blocks or complete engines.
Please message me if you have anything.
Mgc340 is offline   Reply With Quote
Old 09-30-2020, 04:05 AM   #2
Phillip marvetz
Phillip marvetz's Avatar
Default Re: ISO Small blocks Mopar x and R blocks
PM sent
2009 V/SA Record Holder
Old 09-30-2020, 09:32 AM   #3
340Cuda
Liked 804 Times in 341 Posts
From what I understand the new Ritter blocks (not the first ones) are good products.
They don't sell for much more, if any, than the asking prices for some NOS R3 blocks.
I know of at least two quality machine shops that can do CNC work of them.
Last time I looked they were NHRA approved.
Old 10-01-2020, 07:10 AM   #4
427FE
427FE's Avatar
Liked 348 Times in 79 Posts
A buddy of mine has a Ritter block ( not a 1st one) and has a crack in the coolant passage which appears to have been welded right from Ritter. One of the oil drain back hits right into the oil pan rail, upon many other problems.
427FE is offline   Reply With Quote
Old 10-01-2020, 09:28 AM   #5
340Cuda
That is too bad, sounds like stories from the first gen blocks. I think Ritter would have made that good. However that does not help if you already have a money tied up at the machine shop.
Old 10-01-2020, 07:23 PM   #6
427FE
427FE's Avatar
He has every bit of 5k into it. Ritter is actually coming out to inspect the block. Ill let you know what happens.
Old 10-11-2020, 10:43 PM   #7
Ray Vignogna
Give me a call at 845-590-9522 I have a 340 high compression engine built by Bub Whitter as well as a new x block.
Ray Vignogna is offline   Reply With Quote
