Liked 708 Times in 285 Posts
When using a stock balancer and you have 2 marks on it, one for top dead center and 1 for your desired total timing. Always know which one is which. My pathetic performance yesterday at Az S/SS event was due to setting timing at top dead center mark. I wondered why car started up so easy and I had to reset idle. Another lesson learned on how to slow a car down and lose a race. I think the heat got to me.
#2 | |
Liked 358 Times in 83 Posts
#3 | |
Liked 167 Times in 81 Posts
Probably ran a little hotter than normal too.
Tim Schmackpfeffer 762 SS |
those little white paint pens work well.
Liked 127 Times in 26 Posts
Jeff how much slower did your car run from your normal timing
Man, that would really suck. Everybody has had things like that happen (if you've been racing for a while), which is why nobody thinks your mistake is dumb or funny. On the bright side though, at least it was an easily correctable mistake, versus something like a cam lobe ground off or broken transmission.
Liked 292 Times in 147 Posts
I use fluorescent paint pens. White for TDC, green for total timing, and red for 90 degree marks for valve lash.
