Old 09-22-2020, 12:57 PM   #1
Bill Bagley
Bill Bagley's Avatar
Liked 31 Times in 10 Posts
Arrow 2012 Performax 30ft Tag V-Nose
  • 25,148 documented miles
  • 4,300lb curb weight / 12,000lb gross vehicle weight rating
  • All steel MIG welded box tubing frame
  • Aluminum tread plate rock guard on V-nose
  • Electric Tongue Jack; 2-5/8” hitch coupler
  • (2) drop-down stabilizing legs at front corners
  • Interior floor length is 27-foot plus 3-foot V-nose
  • Spring-assisted rear door w/aluminum tread plate floor and fold-down ramp flap
  • 54” curb-side double entry doors w/removable aluminum step
  • 36” driver-side access door located midway above axles
  • 6,000lb Dexter torsion axles, E-Z lube spindles, electric brakes
  • New brake shoes, inner wheel bearing seals and repacked bearings June 2020
  • (5) 16” American Racing aluminum wheels
  • (5) 215-80R/16 Firestone tires, (3) are less than 6 months old
  • One Piece .040 aluminum roof
  • .063 Prepainted Aluminum Exterior side walls
  • .040 Prepainted Aluminum Interior ceiling and side walls, fully insulated throughout
  • Smooth aluminum interior floor, dove-tailed in rear
  • 60" x 20" Aluminum fold-down worktable; mounting posts for inside and outside use
  • (2) Full length E-Track runners for cargo/vehicle tie-down
  • (3) wall-mounted strap hangers in rear
  • (2) wall-mounted 60" bungee strap tracks in front; one high and one low
  • Fire Extinguisher
  • 3,000LB SuperWinch w/50ft fair lead
  • Interior side wall and v-nose carpeted from ground up, 36” high
  • 6’-8” interior ceiling height
  • All metal roof vent, replaced May 2020
  • 110VAC distribution panel feeding LED interior lighting, (2) curb side LED work lights, and 110VAC receptacle outlets
  • Separate 110VAC circuit pre-wired when built to add roof-mounted air conditioner, but never did.
  • New 12VDC deep-cycle Interstate Battery (mounted inside trailer in V-nose)
  • (4) 12VDC interior lights - (2) in front; (2) in back
  • ICC approved LED exterior marker and taillights
  • Extras include multiple E-Track ratchet straps and tie-down accessories, (2) E-Track wheel stops,Equal-i-zer Hitch assembly complete with all accessories ready for installation
Original owner, garage kept most of it's life and meticulously maintained. Never any structural damage, very minor scratches here and there.
$18,500 - (903) 736-0495 Bill
Bill Bagley
4561 STK
Endeavor to Persevere!
Bill Bagley is offline   Reply With Quote
Old 10-31-2020, 12:50 AM   #2
Cody Phillips
Liked 41 Times in 15 Posts
Default Re: 2012 Performax 30ft Tag V-Nose
Bill can you email me pictures of the trailer to cdphillips1992@gmail.com
thanks -Cody Phillips
Phillips auto body Custom paint
Lumberton, NC
910-739-7171
Cody Phillips is offline   Reply With Quote
Old 10-31-2020, 12:19 PM   #3
Bill Bagley
Pics sent, thanks.
Bill Bagley
4561 STK
Old 03-06-2021, 01:43 PM   #4
Bill Bagley
Sold
Bill Bagley
4561 STK
