Old 09-08-2020, 11:14 AM   #1
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default Gold Rush flush anchor d-rings - where to buy?
Hi,
I picked up a 2002 39' GR gooseneck. Is Gold Rush the only place to buy these flush, recessed anchors?
http://www.goldrushinc.com/images/st...rts/dring3.jpg
Thank you,
Clark
Old 09-08-2020, 11:30 AM   #2
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Default Re: Gold Rush flush anchor d-rings - where to buy?
I just GOOGLED flush mounted D rings and came up with numerous types. I'm sure you can find one that will work for you.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 09-08-2020, 12:10 PM   #3
FED 387
Liked 333 Times in 180 Posts
NO--it looks like they took a conventional D ring and installed it from the underneath instead of from the top---makes for a cleaner look that way
Old 09-08-2020, 01:50 PM   #4
cad
cad's Avatar
That is kind of what I am thinking. Just trying to confirm before I order some.
Clark
Old 09-08-2020, 02:00 PM   #5
Kenney Kelley
Liked 72 Times in 36 Posts
Originally Posted by cad View Post
Hi,
Thank you,
Clark
Clark i called Reese Yeagley at Gold Rush 866-478-7245 and was able to get the exact replacement tie downs they come with the exact bolts and hardware and they fit perfectly didn't have to redrill anything for my gold Rush Trailer. Kenney
Kenney Kelley is offline   Reply With Quote
Old 09-09-2020, 10:28 AM   #6
cad
cad's Avatar
Thanks. The GR undermount/recessed d-rings are $33 each.
Old 09-09-2020, 10:17 PM   #7
Kenney Kelley
CAD I changed out all 5 of mine including the one for the Winch Pulley I also noticed the Tie Down Straps were cutting into the Tie Down Eyes and I took a rotary file and lightly chamfered the hooks on tie downs hopefully that will fix the problem. Kenney
