Old 09-07-2020, 06:17 PM   #1
SSDiv6
Default More Garage Cleaning!
Moroso P/N 21245 Chevy Small Block, Boxed Style, Wet Sump, Aluminum Oil Pan. Fits fabricated chassis and chassis with no cross-member. 7 Quart Capacity and 8-1/4" Deep. Double kick-out design allows stroker and main cap clearance. Windage tray and bottom plugs missing. Great condition and never damaged. $250.00 + ride.
Champ Pans P/N CP359LT, 7" Deep, steel wet sump oil pan for Small Block Ford 351 Windsor engines. Six trapdoors, crank scraper, louvered windage tray, provisions for oil temp fitting, oil check level plug, 10 quarts with filter oil capacity. $150.00 + ride.
Meziere P/N FP312 Billet Flexplate, Small Block Ford, 164 Tooth, SFI 29.2, 4 different torque converter patterns. Like new, SFI sticker expired but can be recertified by Meziere. $125.00 + ride
Meziere P/N WP362 Dual Outlet Radiator Mounted Electric Water Pump with mounting plate. Brand New, never installed.55 GPM flow.
$375.00 + ride
Brand new, in the box, Daytona Sensors SmartSpark 24x ignition system with harness for LS1/LS6. The ignition controller with USB interface allows full ignition control when running a carburetor on a LS1/LS6 engine. Includes controller P/N 119007, harness P/N 119002 and software. $350.00 + ride.
Pics available. PM or text Two-Zero-Six, 300-0515
