Old 08-10-2020, 05:19 PM   #1
LethalRat
Liked 4 Times in 3 Posts
Default 92 Camaro Top Sportsman
Former Hooters Top Sportsman Car
1992 Chevy Camaro
25.1 6.0 cert Tube Chassis was told it was built by Carpenter off a Jerry Bickel Kit
638" BBC BES motor, freshened by Reigel Racing engines (26 passes on fresh motor) Edelbrock single dominator cast Intake ported by BES with Induction Solutions nitrous fogger system, Book Carb, HVH super sucker, CFE BMF 405 Conventional Heads, Ross Pistons, Callis Crank, Steel Rods, Jesel Belt, Jesel Rockers, Isky Extreme Zone lifters, Moroso Oil Pump and Aluminum Pan, Moroso Vac Pump ( motor has never been hurt ) Tilton Starter
2 sets of headers ( 1 coated 1 Dynatech Chrome 2.5" with 4.5" Merge Collectors )
Magnafuel Prostar 500 Pump ran on Q16
Dynamic transmission glide Dedenbear Case (26 passes on trans) Coan converter
Outlaw shifter with Biondo Shift Solenoid
Clutch Pedal and brake pressure gauge still in the car if you ever want to put a stick back in it.
10 lb. Nitrous Bottle Mount & Induction Solutions big gauge
Safecraft Fire System
Impact Dual Chutes
Diaper
3 Driveshaft Loops
Strange profab rear housing 40 Spline axles spool 4.33 pro gear
Pro Mod 4 Link, wishbone (all rod ends replaced just a few year ago along with new wheelie bars)
Anti Roll Bar
Front Struts, Strange Double Adjustable Rear Shock
New Billet Specialties SFI Comp Series Front Wheels New M/T Tires,
Strange Brakes
M/T 33x16.5-15S 3084S Tire on Mickey Thompson Pro 5 Wheels
Weighs 2475 with 5'6 165 lb. driver
Dedenbear Crossover Delay box and Biondo RPM Shift Box
MSD 7AL-3, MSD Pro Billet Distributor, Moroso Wires
Hemi Ed built Pro jacks
Been 4.77 @147.29 / 7.44@183.32 on Nitrous
8.00@170 on Motor
Last raced in 2018
Brand New Paint, New Lexan, New Door Panels, New Deck Lid, New Tinman Wing
$45,000 Firm
Fresh Turnkey Race Car
Go Fast with Low Maintence
will not separate - no trades - serious inquiries only
Located just outside of Philadelphia PA.
SST1774@msn.com
ID:	55342   Click image for larger version
Name:	100_6115 resize.JPG
ID:	55343   Click image for larger version
LethalRat is offline   Reply With Quote
