Old 08-07-2020, 06:48 PM   #1
gnicholson
Liked 4 Times in 3 Posts
Default Throttle stops and spacers
I have another question for you guys that's tested this on a dyno. Has anyone tested a radius spacer like an hvh under a throttle stop versus throttle stop directly on the manifold? I meant to test this on the engine dyno when I had my engine on it but didnt. my inclination is the throttlestop is like a big four hole spacer and the hvh spacer would give a little more plenum volume and help the air make the turn a little better
gnicholson is offline   Reply With Quote
Old 08-08-2020, 03:53 PM   #2
Average Joe
Liked 18 Times in 8 Posts
Default Re: Throttle stops and spacers
Having a radius spacer makes more power. Sunset, APD, Stinnett, #1 Stop all offer throttle stops with it built in but a separate spacer works the same.
Average Joe is offline   Reply With Quote
