Liked 230 Times in 75 Posts
Comp rockers 1235-16 ford 5.0 stock style rockers 1.6 ratio $80
Fuel rails mustang 5.0 $50 2 set of Valve covers small block ford 302 or 5.0 These are tall enough to fit roller rockers under them and short enough to fit under stock mustang EFI manifold These are stamped steel very light $20 each Air cleaner stock mustang box K&N part# 33-2015 $25 Comp 4711-16 spring seat $40 new Magnetic collar for ford 9" NEW, ID 2.187, 2 magnets $50 "Flowmaster scavenger collectors, part# C218250350 NEW still in box $125 2 1/8” primary 2 1/2” secondary 3 ½” Final outlet" Weld draglites wheels 15x6 dual bolt pattern, have 2 of them $150 for the pair Holley 1050cfm dominator part# 8896 $500 Firm SOLD Pit pal helmet shelf brand new in box $60 Pit pal style trailer door cabinet Used $60 RJS window net brand new $5 Hughes 9"converter turbo spline stalled 5200-5500 behind BBC Part #BS9D1.124 $400 Moroso spring pearches part# 85090 new in box $15 Moroso competion engeneering off set spring pearches part# C2032 new in box $45 Moroso BBC oil pan part# 20451 used $120 Drive line 3" 38" long center to center, 1350 u joints $125 Drive line 3" 38.875" long center to center, 1350 u joints, with MW 39005 trans yoke PG TH-350 $200 Quadra Jets cores Chevy $50 BPO $75 8 Fram HP4 oil filters these are several years old $50 7 Moroso 22459 oil filters $45 All parts plus shipping Will be in Boise Pm me can text you pictures
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 Last edited by west coast; 08-18-2020 at 09:09 AM. |
