Old 06-25-2020, 03:11 PM   #1
JeremyDuncan
Liked 355 Times in 80 Posts
Default SS 350 295-300/313HP For Sale- Reduced
For Sale Jeff Taylor 1967-1970 Super Stock 350 295-300/313 HP
$11,500 Carb to Pan
GM Bowtie Block 4 bolt mains
Cam tunnel with Roller bearings
50mm Comp Cam
904 Lifters
Small Journal Manley Rods
Diamond 3 ring pistons
041x Heads up cylinder heads reworked by Voges. Ferrea hollow stem valves. Manley springs. Jesel Rocker Arms
Heads up Edelbrock intake
Larry Stewart oil pump
Custom DEEP Aluminum oil pan with draglink through design. (1st Gen Camaro)
SP (Scott Perkins) Edelbrock replacement Quadrajet.
MSD Crank trigger
Jesel Belt Drive
Dyno Sheets available!
Call Jeremy Duncan at 502-817-40
JeremyDuncan is offline   Reply With Quote
Old 08-31-2020, 04:46 PM   #2
NHRA1926
NHRA1926's Avatar
Liked 232 Times in 69 Posts
Default Re: SS 350 295-300/313HP For Sale- Reduced
Is this still available? Missing a couple digits for the phone number listed.
NHRA1926 is offline   Reply With Quote
Old 08-31-2020, 08:37 PM   #3
JeremyDuncan
502-817-4067
