Old 06-21-2020, 04:13 PM   #1
KFMFORD
Default C4 footbrake trans 2.78 gear set
Built with c5 case/ c5 pump-pro-trans 2.78 / 1.58 roller planetary gear set- broader performance reverse manual valve body-modified rev-hi drum with 6 plate alto powerpack kit-5 plate billet steel forward drum with roller bearing-300m input shaft- #9 roller bearing kit- pa billet servo kit- governor hub machined down for weight saving- kevlar bands-teflon pump ring seals- big pump bushing- ptc 8"footbrake converter #8-c4-26-cf-34 with 10 1/2" bolt pattern- converter flashed to 4500 with 500hp motor- b&m deep sump aluminum pan- dynamic locking dip stick- new and fresh in 2019 with only 18 passes-sold car.
$3000.00 call 931-224-0241-if no answer leave message,will return all calls-no text messages,won't answer!!!!!
KFMFORD is offline   Reply With Quote
