Old 06-17-2020, 09:24 AM   #1
bert powell
Liked 34 Times in 12 Posts
Default TH350, BBC, Qjet parts, weather stations
TH350 low drag aluminum drums with updated ATI aluminum drum and 36 element sprag, TCI pump, TH250 gun drilled output and lightened sun shell, Stef’s pan. New JW bellhousing. Best parts. Fresh from Tim Sloan, less than 20 runs since new. $1800
402 BBC Diamond pistons and pins new/unused 4.191 bore .0415/.043/3mm coated top. Will throw in ring set with 4 dyno pulls. $600 Sold
JE 396/350 pistons (6), Crower rods 2.200/.927x2.500 (2 new), new pins. Need 2 pistons to complete $500
290 Heads Up heads, one repaired but would replace or have one excellent spare, with some valves $500
BBC 904 Isky lifters EZ-MAX bearing option excellent condition $400
BBC 904 Isky lifters 376-RHM-904 new $600
BBC Comp 892C 904 lifters good used, one new $250
Misc roller cams std bore $150
Merlin intake, oval port, ported for super stock $400 Sold
Early Q-Jet tuning parts-
Hangers (33) J-Qty 4, H-Qty 4, N-Qty 2, M-2, I-1, O-1, L-5, K-5, P-6, V-3
Secondary Rods (28 sets) DS-4, DH-3, CH-3, DG-8, DU-5, DG-1, DB-2, CZ-1, CP-1
Jets (5 sets) 77,76,74,73,71
Primary Rods (6 sets) .035, .037, .039, .041, .043, .045
$150 for all- will not separate. Sold
Nova weather station in case with altimeter, calculator and sling psychrometer. Calculator works but batteries were dead and will need program from family software. Was the hot lick back in the day $100
Tag handheld unit- works, used up until last year. Bought Race Air. $150 SOLD
82 camaro factory fiberglass hood, one corner needs minor repair $300
Going to Mooresville Friday morning, can deliver.
All plus shipping call or text 9 one 9 96185 zero 5 for info and pics.
bert powell is offline   Reply With Quote
