Old 06-10-2020, 08:33 AM   #1
LS1Racer
LS1Racer's Avatar
Liked 6 Times in 6 Posts
Default bench testing a e shift controller
Is there a way to bench test a e shift controller? I had heard you could use a msd tester. I know you can rig up a 12 volt battery to check for power but not sure about the inputs and outputs. I picked up 2 extras for 50.00 at a swap meet last winter and figured I would chance it if they worked or not for that price.
LS1Racer is offline   Reply With Quote
Old 06-10-2020, 06:44 PM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: bench testing a e shift controller
Yes they can be bench tested using an MSD ignition tester. You could wire in a 12 volt bulb or whatever to the outputs to test them.
Joe Buchanan SS/BX 3117
Old 06-12-2020, 08:21 AM   #3
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Pm sent
Old 06-12-2020, 08:48 AM   #4
LS1Racer
LS1Racer's Avatar
Looking at my MSD igntion tester instructions and my e shift instructions, the controller needs a tach signal so I need to hook up an MSD 7al box with it to get the required tach signal. Is this correct?
Old 06-12-2020, 09:40 AM   #5
Glenn Briglio
Yeah need some info on doing this
Old 06-13-2020, 09:06 AM   #6
buzzinhalfdozen
Yes, that is correct sorry wasn't clear on that. You'll need an ignition box to feed the controller an RPM signal. Never tried using the MSD tester as a direct RPM signal, but it may work using the white wire hooked to the controller tach terminal.
