Go Back   CLASS RACER FORUM > Class Racer Forums > Top Sportsman and Top Dragster
Old 05-24-2020, 03:10 PM   #1
cutta
cutta's Avatar
Liked 5 Times in 2 Posts
Default Can altereds/dragsters sfi spec be upgraded easily?
Guys, I'm not sure that this is the best place to put this question but I figured that more people in the Top Sportsman and Top Dragster forum would be knowledgeable on this. I have plans to purchase a dragster or an altered. I had an opportunity to purchase an altered with a sfi 10.3 cert which is limited to a 7.50ET. That got me thinking about the possibilities of upgrading the chassis to 10.2 cert and alternatively, the ability to up grade a dragster chassis from 2.7c to 2.5c. Thanks in advance for the responses.
Adriel Paradise, Paradise Racing Team
Driver/Crew Chief(at least my dad claims me to be)
B.S. Mechanical Engineering, University of Arkansas
cutta is offline   Reply With Quote
Old 05-26-2020, 03:06 PM   #2
340Cuda
Liked 805 Times in 341 Posts
Default Re: Can altereds/dragsters sfi spec be upgraded easily?
I can't give you any advice other than I would probably check with any of the chassis shops I planned on using.
Old 12-02-2021, 06:36 PM   #3
Bill Baer
I’m not sure on the altered but the dragster may require a larger and thicker shoulder hoop and a thicker and or larger cage also having a chrome plated cage can be limiting you can look up the specs on the SFI website
The 7.50 cert can be for 4 years the faster cert is annually required.
If you want to go faster than 7,50 keep that in mind when shopping for a car, changing the shoulder hoop is a major PIA.
