Old 05-18-2020, 07:54 PM   #1
jerry witzel
jerry witzel's Avatar
Liked 44 Times in 15 Posts
Default Flowmaster collector
On a set of Flowmaster Scavenger 4 2 1 collectors where is the best place to install the crankcase evac fitting ? Should you install it in the side behind the 4 small tubes or behind the 2 tubes ? I'm afraid if it's installed too far back it may not pull enough vacuum.
Old 05-19-2020, 11:03 AM   #2
Mark Ugrich
Liked 71 Times in 38 Posts
Default Re: Flowmaster collector
It was a long time ago , but I tried a set on my 302 bracket motor. I believe I had the bung for the evac placed after the small tubes in the final exit pipe. I never played with them on a dyno, but I don’t remember seeing anything at the track. My advice would be get a set of merge collectors.The 421 deal might pick up a little, but I think it would be more of a fine tuning adjustment.
