Old 05-12-2020, 08:22 PM   #1
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
Default Vacuum pump?
Got the new dragster home, been going over everything and making notes of what I still need before heading to the track. When we put the motor in the car we did not set it up with a vacuum pump, but was wondering if it is worth putting one on it? I am also looking at an alternator, and a few other things more for aesthetics than function, but some things I have always wanted on a car like a digital dial in board and a rear wing.
NHRA: Comp 2200 - S/C 2201
NMRA 2012 Outlaw 10.5 #10
Freddie is offline   Reply With Quote
Old 05-12-2020, 08:25 PM   #2
Keith 944
Keith 944's Avatar
Default Re: Vacuum pump?
forget the wing and board for now put that alternator and vac pump on!
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 05-13-2020, 07:54 AM   #3
Freddie
Freddie's Avatar
Wing and digital dial board will be the last things I do for sure but with buying a new house and moving I will not likely see the track until fall anyway, so I have time to get the car the way I want it before it ever goes out. Headed to the engine shop later this week so I guess I will be picking up a vacuum pump. That should give me something to do for a day or two.
Old 05-14-2020, 02:45 PM   #4
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
A vac pump is nice, but is by no means a must-have. I'd personally rank your listed items:
1. Alternator
2. Digital dial-board (if racing alone)
3. Vac pump
4. Wing
Although, if you're ever going to do a wing I'd do it before you run the car so you won't notice the ET loss.
S/ST 51
S/C 53
Old 05-14-2020, 03:11 PM   #5
Freddie
Freddie's Avatar
1. Alternator
3. Vac pump
4. Wing
The Alternator is on order and will go on as soon as it gets here, the vacuum pump will more than likely be next as I have everything except the pump. I also already ordered the digital dial in board but probably wont have a chance to put that on until after we get settled into the new shop. Still looking for the right wing.
Old 05-24-2020, 11:48 PM   #6
Adger Smith
Liked 880 Times in 311 Posts
The wing can be a problem in windy conditions. New car... I would get it sorted out and baseline it before I added a wing.JMHO
Adger Smith (Former SS)
