Old 04-07-2020, 07:30 PM   #1
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
Default Dragster front tire going flat?
So we got our new dragster not long ago and we used the wheels and tires from our old car since they were only on that car for a few passes. We have always had an issue however with at least one of the front tires going flat over the course of 3 days. They are Goodyears. Was wondering if anyone else had a similar issue? or what can be done to fix this? We are more than likely going to replace all 4 before we run the car, and we did put it up on stands, but not sure why they keep going flat.
NHRA: Comp 2200 - S/C 2201
NMRA 2012 Outlaw 10.5 #10
Freddie is offline   Reply With Quote
Old 04-08-2020, 01:37 PM   #2
voltdr
Liked 100 Times in 51 Posts
Default Re: Dragster front tire going flat?
I fought this problem on my dragsters for several years. I finally put tubes (metal stem motorcycle tubes) in mine and no more trouble.
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 04-08-2020, 04:05 PM   #3
Freddie
Freddie's Avatar
Dan
Called my tire guy today and he said the same thing. he is getting me a set.
Old 04-09-2020, 11:42 PM   #4
voltdr
I found it necessary to enlarge the hole for the tire stem a small amount.
Dan
Dan Foley
SC 4698
Old 04-28-2020, 10:46 AM   #5
gfbdiesel
Liked 2 Times in 2 Posts
I had the same problem on a door car found that the nuts on the back of the stems was loose
gfbdiesel is offline   Reply With Quote
