Old 03-30-2020, 03:51 PM   #1
west coast
Liked 230 Times in 75 Posts
Default Garage cleaning and mustang stocker parts
Have Pictures i can text PM with ph#
Ford 8.8 ring & pinion 4.30 gears M4209-G430M used only a few passes on the 1/4 mile $125
Comp rockers 1235-16 ford 5.0 stock style rockers 1.6 ratio $80
NEW C4 Small Block Ford Chromoly SFI Flexplate 157 Tooth 28 oz SBF External and 50oz $30 each
Foxbody mustang Upper control arms for 8.8 with sperical bearings on both ends adjustable $225
Hotchkis performance Upper control arms foxbody mustang $75
Fuel rails mustang 5.0 $50
Pinion yoke 8.8 ford Stange part# U1630 New $45
2 set of Valve covers small block ford 302 or 5.0 These are tall enough to fit roller rockers under them and short enough to fit under stock mustang EFI manifold These are stamped steel very light $20 each
small block ford roller lifters Sherman short travel $100
Air cleaner stock mustang box K&N part# 33-2015 $25
Comp 4711-16 spring seat $40 new
Weiand Team G, BBC intake manifold, part# 7523, oval port, holley 4150, carb flange
Very clean, excellent shape, no nicks or dings in machine surfaces $250
Dart, BBC intake manifold, rectangular port, holley 4150, carb flange
Autometer tach Pro-comp2 ultra-lite $150
Magnetic collar for ford 9" NEW, ID 2.187, 2 magnets $50
HVC Msd coil part# 8251 $80
MSD pro power coil still good I just change them every year $20
2 large battery boxes new $15 for the pair
Battery switch cole hersee part# 75904? 4 pole for altenator $15
After market seat hi back $50
QA1 coil over springs 12" 100/200 progressive springs one is new the other slightly used $50 for the pair
"Flowmaster scavenger collectors, part# C218250350 NEW still in box $125
2 1/8” primary
2 1/2” secondary
3 ½” Final outlet"
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 05-03-2020, 04:11 PM   #2
BradS
Default Re: Garage cleaning and mustang stocker parts
Do you still have those flowmaster collectors.
If so could you text me a photo. Am interested in them. 3209806763.
BradS is offline   Reply With Quote
Old 05-03-2020, 07:19 PM   #3
west coast
Yep pictures are on there. These are new never been used
Old 05-08-2020, 03:37 PM   #4
Matt Warner
PM sent
Matt Warner is offline   Reply With Quote
