Old 03-21-2020, 03:05 PM   #1
vholley
Liked 10 Times in 5 Posts
Default Garage Sale/Parts & Tools
All items + shipping
PMS-Bellhousing Indexing fixture/no indicator $15
Rod bolt stretch gauge, w/metal frame & strong spring in indicator. I think, it is an ARP $75
Cam checking tool-.fits .842 & .875 bores, w/tool for flat or roller tappets, w/indicator(missing glass) $60
BHJ-BBC valve depth checking bar(I think it has been discontinued by BHJ) $20
MANLEY- Lash cap puller-$20
Assortment of Jesel & T&D shims, hold down bolts, etc(mostly Jesel, NO rockers)+2 different valve spring replacement tools for shaft rockers.(Similar to Powerhouse #351035) $75
Edelbrock Torker #2725 w/frt oil fill hole, used very little, all surfaces good. $50
ACCELL BEI, pt #35100T Chev. distributor, w/3 ignition boxes, tach drive $100
SUN Electric LVT-33 leak down/vacuum tester $75
Tapered ring installers,
B&B 4.600 w/step to use with o-rings $30
ARP 4.125 w/step to use with o-rings $30
Childs & Albert 4.560 w/step to use with o-rings $30
Generic (no brand name) No step
4.530 $25
4.500 $25
Call, text or email for pics & info
317-442-5938
vicholley4@yahoo.com
vholley is online now   Reply With Quote
