Old 03-12-2020, 06:33 AM   #1
Matt S
Liked 20 Times in 12 Posts
Default Spring Compressor Thread Size
What is the standard thread size for common coil spring compressors? Appears to be 5/8-10 ACME threads, but this particular thread size seems relatively uncommon in terms of ACME threads. I need to remake the threaded rod for my spring compressor, as it's not long enough to sufficiently compress the taller drag race-style springs.
Matt S is offline   Reply With Quote
Old 03-12-2020, 09:09 AM   #2
jimmyparker
Liked 309 Times in 88 Posts
Default Re: Spring Compressor Thread Size
I don't remember the exact size of mine but when I searched ACME threaded rods on McMaster-Carr's website I was able to figure it out based on the info they provided with the rods.
jimmyparker is offline   Reply With Quote
Old 03-12-2020, 09:43 AM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
make sure the rod you get is 4140 ,not 1018 .......The tensile strength of 4140 is double that of 1018 .
Yes , I learned this the hard way !
