Old 02-19-2020, 07:33 PM   #1
BCAMM
Default P/G planetary,18 degree sheet meta intake,etc
1.98 P/G Trans Specialties planetary set (helical cut) never used.
$600.00
15-18 degree SBC TRE sheet metal intake,(2) single 4500 tops (2" & 3")
$1000.00
353 CI rotating assembly;
10 new Probe Industries 18 degree SBC pistons 4.125 semi finish dome,
lightened (454 grams),valve pockets plunge cut for 2.200 int./1.625 exh.
gas ported,.043/.043/3mm oil ring, 1.35 comp ht.
8 new Groden aluminum rods 6" Honda rod journal 1.887 (450 grams)
LA Billet crank lightened by Crankshaft Specialties,knife edged,350 std. mains,honda rod journals
$3000.00
210-257-5582
BCAMM is offline   Reply With Quote
