Old 02-19-2020, 05:29 PM   #1
3060ssga
Default 396/375 stock eliminator
Everything new 396/375hp nhra stock
dyno time 5 pulls break in only
618hp on dyno
Big M dart small bore block water between cylinders
+.035 over
stef's oil pan and pump
manley pro series rods
plus +.013 steel crank
cp pistons 2 spares
total seal rings
comp cams rockers & nitrided cam
pac springs, tool steel retainers
ferrea stainless valves
trend lifters & push-rods
GM performance heads
Lloyd Creek flow management heads
and intake
Fabricated valve covers
ATI balancer aluminum hub and shell
comp cams billet adjustable timing chain
all ARP bolts
MSD Pro-Billet Distributor
new spare comp cams rockers aluminum
moroso plug wires red or blue
new meziere 42 gpm water pump not on engine red or polished
2 carbs 780's
Quick Fuel and Gary Stinnett.
trade for super stock chevy small block 350/300hp no junk thanks.
$13,000 mark (502)802-0382
3060ssga is offline   Reply With Quote
