Liked 880 Times in 311 Posts
Can Grade points from super street be used to get into an national event in stock or super stock?
Adger Smith (Former SS) |
Liked 1,958 Times in 593 Posts
I am pretty sure that you can use your grade point in any class that you have a license or permanent number for. But you can only use them in one class. If you have 8 and enter say Super Stock. Then your points are used up for that event. You can’t souble enter unless you have enough to do that.
Mike Pearson 2485 SS |
Liked 314 Times in 177 Posts
Liked 140 Times in 46 Posts
I don't think that's accurate. I entered SS 2 years ago at Norwalk because stock was full. I've never had a SS GP....ever.
Jon Sarrett Stock 3779 |
Liked 3,230 Times in 982 Posts
Jon and Mike are correct.
Liked 283 Times in 80 Posts
According to Cody Savage SST, TS, TD grade points can be used to enter ST,SS,SG,SC. Grade points from those 4 classes cant be used to enter the other 3.
Liked 431 Times in 224 Posts
That is correct. Since SST, TS, and TD are not contested at every national event, only grade points earned in those classes may be used to enter.
S/ST 51 S/C 53 |
