Old 02-14-2020, 05:29 PM   #1
Alan Freese
Liked 43 Times in 11 Posts
Default Coan, Protrans, MW, Monocoque
Coan 7" bolt together aluminum convertor. Choice of #4 or #5 pump. Choice of 30-13, 30-15, 30-17 or 30-17-22 stator - $3200. Additional stators @ $300 each
Sale pending
Protrans - 245/145. all new steel and frictions, case has a hairline crack - non pressure area and leaks - needs to be professionally welded. Previous owner had epoxied - I've had it 5 years and been fine but should be welded versus epoxy, I can send pictures - $3000 sale pending
MW 6.20 third member, 3.812 aluminum case, lightweight 40 spline steel spool, MW steel yoke and large bearing support, light weight / back cut pro gears, Racepak 2 magnet collar - no pickup- $1200 sale pending
MW 5.83 third member - same specs as above - $1200 sale oending
Monocoque Wheel set super lite style (round holes) - need a lil TLC - (center beads need to be resealed). Fronts 5 x 4 3/4, rears 15 x 14 dual pattern - $800
(4) Hogan SBC Shortdeck 2x4 manifolds - $300 each
All prices plus freight - Can by delivered to Phoenix. Pictures available on request.
Contact: Alan @ 831-595-4720, call or text is fine. Thank you, Alan.
Alan Freese is offline   Reply With Quote
