Old 02-12-2020, 05:30 PM   #1
4spdJohnny
Liked 137 Times in 46 Posts
Default Want to buy Jerico parts
I am "restoring" a older DR4 for a friend. I am looking for a "chevy" length input. Will take either a 26 spline or a 18 spline. The trans has no serial number but it is a early 90's drag box as near as George at Jerico and I can tell. The problem I'm running into is all the inputs I'm finding the distance between the snap ring grooves outside to outside is either narrower (at 2.240) or wider (at 2.54) This trans has the older 209 bearing with the larger 1.770 bearing register but has "wide" gears so the snap ring groove width is 2.340. Please let me know any info call or text if you have an input, thanks!
John A. McLaughlin
605-237-8673
John A. McLaughlin
5757 B/S 440-6 or G/S 383 70 Road Runner, Dad's
5096 K/SA 70 Two Ton Tamater, Taylor's,Alec,Breezy
4spdJohnny is offline   Reply With Quote
