Old 10-22-2007, 05:34 PM   #1
Brad Zaskowski
Brad Zaskowski's Avatar
Liked 130 Times in 20 Posts
Default Big Garage sale
Zaskowski garage sale
-Liberty Australian clutch less five speed transmission magnesium case pistol grip shifter 1st 3.44 2nd 2.28 3rd 1.65 4th 1.28 5th 1.1. 10 and 18 spline inputs for 8 5/8” belhousing, and 18 spline input for 7 1/8 belhousing. Under 50 runs old never broke $7900.00 new get it now for $6,500
-Browell Belhousing steel 8 5/8” starter pocket, candle stick with computer pickup hole, bickel clutch fork, inspection / adjustment hole. We used with sb Chevy and liberty trans. Needs to be re-cert. $1,000
-Ray franks 7” dual disc clutch 142 tooth flywheel 10 spline discs titanium floater 6 extra discs. $3,000
SOLD-GPE starter for sb Chevy for 142 tooth flywheel passenger side mount $200
-Hays 8” single disc clutch 18 spline disc, 168 tooth flywheel includes spare disc $1,400
-Visner Engine design 15* sheet metal intake 2-carb intake and carb spacers made over 700hp on our 292 Chevy $1,500
SOLD-Davinci 750 cfm carb we used on 292 to run G/SM $600
-2 davinci 750 carbs rebuilt by Book in 2007 ran 9.21 in H/SM this summer $2,000
-Rochester 4gc Super Stock Carb built by Davinci $500
-1 GM head bare casting #24502615 $750
-MGP Aluminum rods 5.850” .927 pin 2” journal dyno time only $500
-MGP Aluminum rods 5.700” .927 pin Honda journal 40 runs $300
-Jesel belt for sb Chevy complete $500
-Moroso single stage oil pump includes all pulleys and belt $600
SOLD-Moroso Vacuum pump kit complete Pump #22640, 5” pulley #64885, belt, crank pulley and mandrel, all braided lines and fittings, and breather tank. $500
-Stefs sb Chevy oil pan with fitting for external oil pump #K23411298 $300
-CSI red anodized water pump for SB Chevy includes radiator hose adaptor $150.00
SOLD-MSD 7AL-2 ignition box older style checked out by MSD in July 2007 $200
-Brand new PSI valve springs 8 total pn# DR 1253 ML $200
-Mark Williams 40 spline light weight spool pn#53137-B $250
-Hoosier front runners #18105 26.0 4.5-15 only 35 runs like new $175.00
Every thing must go, no reasonable offer refused. Shipping not included in prices.
Email brad@zaskowskibuilders.com
Brad Zaskowski 3697 STK, SS
Brad Zaskowski is offline   Reply With Quote
