Old 01-19-2020, 10:52 PM   #1
Mike Mans
Liked 299 Times in 48 Posts
Default Parts and Tools
Comp Cams 5462 LS Valve Spring changing tool, new in box. Used once, $75 SOLD
Trick-Flow 90306 LS Valve Spring changing tool, new in box, never used, $50
Carb Spacer: Rubber insulator carb spacer. Cloverleaf inside, 1” thick. Helps to settle carburetor vibrations for smoother operation. $75 SOLD
ECM AFM1000 o2 monitor system, has Racepak VNet adapter, still arguably one of the most accurate and fastest reacting systems available. These are $1,900 new. $650
SBC Header Adapter Plates. These are designed with steel thread inserts so you don’t have to deal with stripped threads. Ready to bolt on and port when doing new heads. $100
STEF’s 727 Torqueflite sheet aluminum pans. They fit great and have filter spacers, but are not in perfect shape. Have 2 available. $50 ea or both for $75. SOLD
Oldsmobile 350 ci BHJ Hone Plate $200 SOLD
McClintic left hand starter mount for SBC, brand new $250 SOLD
ProTrans #2 Planetaries, 3 pinion with inner ring gear. Have 2 available, $350/ea SOLD
ProTrans Torqueflite Powerglide stator support. Have 2 available, $200/ea SOLD
MSD Digital 7 Ignition 7535, only used as spare and for troubleshooting. No harness but includes 2-step RPM selector module, $400
Chevrolet 441 castings, very nice, untouched set of castings - bare. $250 for the pair SOLD
See add for pictures: https://www.racingjunk.com/Stock-Sup...and-tools.html
All prices plus shipping
Messages or text Randy Mans @ 612-306-5387 for any more details
Mike Mans is offline   Reply With Quote
Old 01-20-2020, 08:53 AM   #2
rocketman269v
rocketman269v's Avatar
Liked 4 Times in 4 Posts
Default Re: Parts and Tools
PM sent. Thanks, Bob.
rocketman269v is offline   Reply With Quote
Old 01-24-2020, 04:19 PM   #3
rocketman269v
Thumbs up Re: Parts and Tools
Block plate arrived today; just as described and in very nice condition. It was packed very well. A pleasure to deal with and quick shipping. Thanks, Bob.
