Old 01-15-2020, 08:54 PM   #1
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default 390 amc superstock engine package
so after collecting these parts for my superstock 390 build ,I am possibly heading in a different engine build ,so I am looking to sell as a package
(1) 401 standard bore block
(2) .060 fresh bored blocks that need final hone to fit pistons
(1) 390 rotating assembly
new 4.225 cp flat top pistons (w/valve 2 notches)
new scat rods full floating
crankshaft offset ground to 390 and sized to 2.090 (360 size)to fit scat rods ready to be installed
crank work performed by ohio crankshaft
matching 6mm ring set for cp pistons
(3) sets of 993 heads ,these have not been decked standard and have no cracks on the bottom head bolt flange
(1) 390 crank .030/.030
(1) rollmaster timing gear set
(8) JE pistons 4.185 ,1.00" pin (stock replacement ) used excellent condition can be used with stock rods
have receipts for pistons/rings/rods/crankshaft work
"$5500.00 for the entire package"
note:will do partial trade for complete gen3 hemi engine 5.7 core 2009 and up
please contact with serious offers /pictures available
860 250 8068 call or text
