Old 10-21-2007, 11:09 AM   #1
G Schenck
Liked 81 Times in 35 Posts
Default Bill Holt's call !!!!!!!!!!!!!!!!
I can understand if stock ran Friday and it rain out Sat. ,you should put the racers at the bottom of the qualifying sheet. But those two cars had every opportunity to run Sat. BTW is that Cobalt a real stocker or just a rent a car. How can you go to five races and never go down the track and next year he will be taken a spot at a National away from a real racer. Also it gave #31 and #32 a bye first round instead of giving the #1 a bye in the second round.
Greg
G Schenck is offline   Reply With Quote
Old 10-21-2007, 11:31 AM   #2
Tony Janes
Default Re: Bill Holt's call !!!!!!!!!!!!!!!!
The NHRA rule book say pass tech 1 gade point and 10 points
Tony Janes 7941 STK, SS
Old 10-21-2007, 11:59 AM   #3
G Schenck
A rental car cannot pass tech and should not be inserted into the ladder.
Greg
Old 10-21-2007, 12:20 PM   #4
jerrym
Greg
I AGREE in 2005 I lost the IHRA World Championship when the guy flew to the race and entered a rental car...Totally B U L L S H I T
Jeremy Mitchell
jerrym is offline   Reply With Quote
Old 10-21-2007, 12:52 PM   #5
JRyan
Liked 112 Times in 31 Posts
Greg,
I don't agree with the rental car concept either, but other than fuel check (which is not done until after the run), why would a lower class FWD rental car not pass tech? AND, if you were ambitious enough to rent a car at home, remove the catalytic converter and add race fuel, and develope a program for a given car, and then always rent that same type car at any given race, you might be a contender, and never own a race car or even a tow vehicle for that matter.
Jerry
Old 10-21-2007, 01:52 PM   #6
G Schenck
I thought you had to have 1/2" bolts holding the battery down, no coolants and aftermarket racing wheels but after looking at the rule book I guess not. My main concern is putting them in the program knowing they cannot run causing the ladder to change. Also could have made it a 65 car field and could cost someone to lose a divisional or national championship.
Greg
Old 10-21-2007, 03:58 PM   #7
Bob Bullock
That's funny Jeremy, I thought you lost the championship because the other guy earned more points than you!
Bob Bullock is offline   Reply With Quote
Old 10-21-2007, 08:23 PM   #8
dean ribeiro
Liked 241 Times in 80 Posts
I believe Bob is correct!
If a rental car is so bogus or bull****, try renting one next time. Maybe we should outlaw FORDS? or maybe racers who do not run the entire length of the track under full power???
seems to be a lot LESS whining at the track!
dean ribeiro is offline   Reply With Quote
Old 10-21-2007, 08:55 PM   #9
G Schenck
Dean, We're talking about a car that's not going to see the track and inserting it into the ladder. That is Bull****!
Greg
Old 10-21-2007, 09:22 PM   #10
David Lee
Liked 346 Times in 126 Posts
Greg
I have no problem with a rental car running if it can pass tech and run the number. If it was entered to to change the ladder makeup thats a completely different call.
For the past six years I have been involved with off road desert racing. I could not figure out how the top teams would always get a great starting position on the grid. Later on I found out that they would enter buggies and trophy trucks that did not exist, since the entry fee was refunded. They would use th ebest position they got on the lottery. Finally SCORE put and end to this,
