Old 12-29-2019, 10:39 PM   #1
drgrcr
Default 96 S10 for O or P stock
truck is sold
1996 2wd S-10 set up for NHRA stock eliminator, will classify and run well under the index in O or P stock automatic. Titled in my name in NJ. I will not sell this as a rolling chassis. Very clean interior/exterior, ZERO rust anywhere. Always stored indoors. Full cloth interior. The engine (never fired 4.3 bored .040 over) was built by Bobby Warren race engines in North Carolina. A B&M TH350 with the kickdown and vacuum modulator blocked off. A Turbo Action converter for small cubic inch to stall between 4500 and 5000. This truck has a hard to find factory 2wd S-10 8.5 inch ring gear rear end. It is spooled with a 5.57 gear and stock axles. Caltrac bars installed and split leaf springs in the shipping wrapper, 30 inch Hoosier drag radial slicks for the rear and MT front runners with the stickers still on them all on new Weld drag lites. Lightweight one piece hinged tonneau cover with lifting shocks. 5 gallon aluminum fuel cell with a Aeromotive 1000 fuel pump in the bed. There is no headers or exhaust included. A lot of little goodies are included that aren't installed, fuel pressure gauge, gauge isolator (high pressure), regulator, car cover etc. $7800 as is/where is. THIS WILL NOT BE SOLD AS A ROLLING CHASSIS. I will sell the engine and converter seperate and keep the roller if interested. Pictures here; https://southjersey.craigslist.org/p...036842880.html. If you did indeed read this ad, I still have the truck for sale so please don’t ask if its available.
Please call, located in southern NJ; 609-350-4255
drgrcr is offline   Reply With Quote
