Old 11-29-2019, 11:34 AM   #1
Jddj
Liked 2 Times in 2 Posts
Default 68 ford cylinder head flow numbers
Will or can anyone enlighten me on some of their personal experiences with the flow numbers from a head that has not been welded on and what kind of performance they are getting?
Jddj is offline   Reply With Quote
Old 11-29-2019, 04:43 PM   #2
Tom Broome
Liked 88 Times in 43 Posts
Default Re: 68 ford cylinder head flow numbers
Perhaps you could clarify which 1968 Ford you are asking about.
Which exact cylinder head casting, Stock or Super Stock?
Not that I expect anybody to post those details on a public forum.
Tom Broome is offline   Reply With Quote
Old 11-29-2019, 06:40 PM   #3
Jddj
1968 Cougar 302 4v C80 e-f. I found the stock numbers on the engine spec page. I am wanting to know what one could expect to get from them with only port work,no welding or epoxy? But maybe as you said no one will give any numbers out.
Old 11-29-2019, 09:06 PM   #4
HP HUNTER
Liked 373 Times in 129 Posts
The late Kip Martin my best buddy, I miss that guy, his record holding SS/L 220 HP 289 made 467 STP HP @ 7400 RPM, heads flowed 217 CFM @ 28 inches, and he only flowed 1 port LOL. Try getting information like that from most of these super secret class racers. Ran 10.27 @ 127 1.30 60 foot.
Old 11-29-2019, 10:06 PM   #5
Jddj
Cool Re: 68 ford cylinder head flow numbers
HP, thanks for this. My car will be in GT/MA or NA The heads that are on the engine right now flow 202. It is legal but it was off the index alot. So I need to get a better setup. It will be my first S/S ride and I was hoping to get some more input before I make a decision on what to do. I am not looking to set a record,I just want to be able to compete nelow the index.
Old 11-29-2019, 10:13 PM   #6
HP HUNTER
Now you know, happy to help. Lloyd Creek did his first heads, wet flow with 212 CFM if I remember correctly, set the first record with those, then reset the record with his own heads. Kips engine was very simple to some degree, the clutch....not so much. I'd be happy to tell you what I know about the engine.
Old 11-29-2019, 10:27 PM   #7
Jddj
You can send me your contact info on a PM if you don't mind.
Old 11-29-2019, 10:29 PM   #8
HP HUNTER
719 650-1609 Mark
Old 11-29-2019, 10:29 PM   #9
Capri
Liked 27 Times in 14 Posts
LOL @ 219 with 289 heads................... I will say no more than that.
Capri is offline   Reply With Quote
Old 11-29-2019, 10:34 PM   #10
Jddj
Mark I will give you a call tomorrow thanks.
