Old 11-14-2019, 05:08 PM   #1
NHRA3106
Liked 147 Times in 38 Posts
Smile 2003 Dodge 3500 2wd
Clean white truck w/235,000 miles, manual trans, Firestone tires w/5k miles, just spent 1,800.00 replacing the heater/evaporator core box, compressor and dryer...A/C is cold! Has a brake controller, ball in bed w/light hookup in bed, and bumper. Fall of 2018 I put an upgraded tow/haul brake kit (has drilled and slotted rotors) with hoses on front, new upper/lower ball joints, and tie rod end links on rack, and aligned. Put new stock brakes on rear at the same time. It has a Smarty Jr programmer new in 2018. Solid truck drive anywhere, gets 18+ miles per gallon empty. Only issues known to me are the hood struts are weak, and the cruise doesn't work. Located near Lexington, KY, ad in Lexington area Craigslist. Asking 15K OBO. For additional info call or text Kevin@502-316-4667
NHRA3106 is offline   Reply With Quote
