I'm looking for the fuel tanks that go in the truck beds.. People that make them or used ones. It would have 2 fit an 04 f-350 thanx
No prep is king |
Keith try northerntool.com or tractorsupplycompany.com.
They list them under fuel transfer tanks. I got mine from northern tool, 60 gallon tank with storage on top of the tank about $600.00. The brand name of mine is RDS. |
Liked 334 Times in 181 Posts
For diesel or gas???? There is a co. in texas advertises in Dragster but they are EXTREMELY expensive--If you get gas make sure it is DOT accepted--not sure how it works with diesel-----If you have a truck salvage yard in the area you can usually pick up used Semi tractor tanks for about a buck a gallon maybe less if you shop around--Otherwise if you have any Farm supply stores in your area they carry them---also look on ebay under aluminum fuel tanks or truck fuel tanks might be able to pick one up in your area---Comp 387
thanx guys
No prep is king |
Try www.Supertanks.com. Their tank replaces your old tank with a larger one and you don't lose the bed space.
try these nuts
yaaa hheeeeheheheheh
No prep is king |
Liked 12 Times in 4 Posts
Keith,
We install supplemental tanks all the time and carry a very large assortment and offer installation although we are located in Mississippi and are probably too far away for the install. Give us a call at 601-371-0815. |
Liked 1,853 Times in 433 Posts
How about fuel? You still running C-25 in that truck?
james perrone 1290 STK |
Liked 502 Times in 120 Posts
you just trying to get a big enough tank to hunt down witherspoon ???
just joking ... jack mccarthy
Jack McCarthy 3609 STK "the Captain" |
