Old 11-02-2019, 10:34 PM   #1
Kevin Panzino
Kevin Panzino's Avatar
Liked 759 Times in 139 Posts
Default 3,000 HP, 2,500 Ft Lb Water Brake Dyno
I am selling a 3,000 HP, 2,500 FT *Lb water brake dyno in partial order. This unit has the identical absorption unit to the SuperFlow Black Widow dyno, a Froude Type F24 absorption unit. This absorption unit can actually hold the full rated 2,500 Ft*Lbs at as low as 1,500 RPM. Comes with an engine cart, cooling tower unit, and control desk. NO CONTROLS. These units were originally designed and started being built by Digalog in the early 2000's and were to be the pinnacle of water brake dynos. Only about 6 of these were ever built to my knowledge, due to the cost (over $110k in 2002) and Digalog being bought out by AVL who only focused on OEM testing systems. I purchased 2 of these at an auction. I am currently running one of these, with the Digalog Benchmark control system in my shop now. This unit I am selling has had the control system and water valves stripped prior to my purchase. It looks to have hardly ever been used, the cooling tower unit clearly never used yet. You will need to install inlet and outlet water valves, and a suitable control system and you have an 3,000 HP dyno for under $50k. I inquired with SuperFlow and they estimated around $20 to $25k for everything else needed to complete the dyno, including their latest control system. As a cheaper option I would have also recommended Depac, but unfortunately Mr Depak Dave has passed away. I can explain all about this unit, what I had to do to get mine running, and can help with fabricating the adapters etc. I have much more info about this monster than I can put on here, and can explain more on the phone. I will also be at PRI, and can discuss there in person.
Pics on Racing Junk ad # 183988174
Kevin Panzino
724-640-0818
