Old 11-02-2019, 05:58 PM   #1
Jess Suter
Liked 7 Times in 4 Posts
Default 1971 340 Stock eliminator
1971 340 STOCK ELIMINATOR
Built by Watson Engineering for me. I was hoping to get better, but illness forces sale.
This is a brand new R3 block (P4876795AB) filled with the best parts
Here is the invoice on the build:
Sales Person Our Order Number
1.000 MAXIMUM LIGHTEN & BALANCE 270.00 270.00
PISTONS
8 DIA0103S CUSTOM FLATTOP PISTON 177.00 1416.00
INCL-PIN FIT, RING CUTS, OIL
RING BORE, ETC.
P4876795AB R3 BLOCK 2687.50 2687.50
EPMS1344P MAIN BEARING SET 39.90 39.90
8 EPCB481P ROD BEARING 4.10 32.80
340CHRY CRANKSHAFT CORE 185.60 185.60
340 MOPAR
1.000 OFFSET GRIND, RIFLE DRILL 450.00 450.00
ROD END, NITRATE
1.000 BALANCE CRANKSHAFT, CUT 350.00 350.00
COUNTER WEIGHTS, ZERO
HOLES
......- OIL PUMP - _... - - - - ~ -..,r - --- -.-:.. _:::... _~_ ,..._ ,<_-' .. _, . ..,;.,':" - ----.
1 - MELM72 27.80 27.80
MEL72S2 OIL PUMP SCREEN 26.50 26.50
08-2004 SB TIMING CHAIN . 147.50 147.50
MAN 14139C-8 CHRY RODS 787.30 787.30
. (8 PCS)
1.000 DECK BLOCK 120.00 120.00
8.000 BORE BLOCK 4.080 12.50 100.00
1.000 HONE BLOCK 240.00 240.00
1.000 LINE HONE 120.00 120.00
1.000 LIFTER BUSH 450.00 450.00
16 BHJLBS-843-50mLlFTER BORE SLEEVE 7.20 115.20
1.000 INSTALL CAM BEARINGS 40.00 40:00
DBPDP16 HP BEARING SET 52.50 52.50
1.000 ASSEMBLE SHORT BLOCK 750.00 750.00
FOB 85298
I need to get as much as possible for this short block
Help me out if you can. Thanks and God bless
$9000 OBO cash speaks loudly
jsuter@earthlink.net
@NHRARACER
602-723-6602
Jess Suter
7305 Stock/SS Duster
"life is not a rehearsal"
Jess Suter is offline   Reply With Quote
