Liked 2 Times in 1 Post
Kaase Racing Engines version of the ’16-’17 COPO 350 supercharged 580hp rated Chevrolet performance crate engine
Just completed 4/19 engine has dyno time on it only, never been down a racetrack. Made 1145hp on Kaase dyno with very mild tune up. Great motor for NHRA Stock/Super Stock competition! Upgrades over stock include Kaase roller Comp cam and roller lifters and DMPE supercharger upgrade with ceramic bearings, coated rotors, etc. Components include; • Block: Chevrolet Performance LSX cast-iron with steel main caps • Crankshaft: Callies 4340 "Dragonslayer" - double-keyed snout • Connecting Rods: Callies 4340 H-beam "Ultra" Forged Steel, 6.350" Length, .927" Pin Bore Diameter • Bearings: Calico coated main and rod bearings • Pistons: Mahle forged 2618 alloy, Dome Top, Graphal coating, Friction-coated skirts • Camshaft: Kaase spec Comp roller Cam; Theoretical Valve Lift - .641" int. / .641" exh. • Pushrods: 3/8" diameter LS7 • Rocker Arms: 1.8:1 ratio LS7 with roller trunions • Valve Springs: Performance Springs Incorporated (PSI) "Max Life" beehive • Cylinder Heads: Fully CNC'd aluminum based on LSX LS7; Nominal Intake Port Volume - 289cc; Nominal Exhaust Port Volume - 105cc; Nominal Combustion Chamber Volume - 70cc • Intake Valves: Del West titanium 2.205" (Head Diameter) x 8mm (Stem Diameter) • Exhaust Valves: Lightweight sodium-filled 1.615" (Head Diameter) x 8mm (Stem Diameter) • Head Gaskets: Cometic multi-layer steel with raised cylinder sealing bead • Oil Pump: Internal wet sump • Oil Pan: Stefs Fabricated Aluminum • Harmonic Damper: ATI Performance Products SFI-approved "Super Damper" w/10-rib shell • Water Pump: Chevrolet Performance LS3 • Intake Manifold/Induction: DMPE upgraded Whipple Industries 2.9L twin-screw superchager • Throttle Body: Whipple Industries - Billet Aluminum 109mm, Cable-actuated • Fuel Injectors (Flow Rate): 80 lb/hr @ 43.5 psi with EV1 connector • Ignition: Production LS7 ignition coils and secondary wires Call or email 630-660-3756 bman3040@comcast.net |
