Liked 708 Times in 285 Posts
Finally made my first divisional in years with Oldsmobile. Totally missed carb jetting and trying to shift at high rpm's.
Couldn't run index the first 2 passes. Received some great advice from Greg Marshall,Darren Summerton and some carb tuning from Mark Yacavone. Ran .08 under index Saturday but fought oil leaks. First leak was oil filler plug fell out and blew oil all over compartment,but not on track. Fixed that and after checking valve lash I pinched a valve cover gasket and it leaked on next pass. Found that problem and fixed it, or so I thought. First round it leaked again. Luckily everything went on headers and made a ton of smoke and did not get any oil on track. Ordered new breathers,gaskets,carb jets. Clean up mess and start over. I will keep trying to get this thing to run. I had allot of racers tell me it's a great combo to run. |
Liked 7,903 Times in 1,754 Posts
It IS a great combo and it looks like you were getting advice from the right people. Keep up the good work!
Liked 53 Times in 13 Posts
Jeff, never quit! you're doing good. those are minor things at least you made it to the track safe. I know what you're going through I finally got my Super Stocker running after switching from SBC carb to an LS FI. stick to an auto. keep up the good work and good luck. Luke
Liked 452 Times in 134 Posts
Jeff glad you got to go to the divisional, keep working on it you'll make it work . I love wagons have had a couple and i think they make great stockers.
Jerry 3490 3492 STK SS SST |
I love this car. Some days are just throw aways, keep at it.
Todd Greene |
Liked 140 Times in 46 Posts
Keep plugging away Jeff. I remember sitting in the water box behind you at speedworld on many occasions waiting to get an awesome view of your hood on that bumper dragging Monte Carlo! I've got faith in you!
Jon Sarrett Stock 3779 |
Thanks everyone. I really felt bad smoking the track and I did hear about some complaining. Jon those were the days with that Monte
Liked 223 Times in 73 Posts
I've had a lot of trouble with oil leaks from valve cover gaskets. I finally got cast aluminum valve covers and I use rubber gaskets with the steel insert, and I tighten them down a lot. That solved it for me.
It was great to see you out there. I love station wagons and yours looks awesome! |
Liked 302 Times in 73 Posts
Jeff,
Hoping you can get the small leakies fixed and come get some more runs on the car on the 20th at WHP! Sounds like you're making great progress after only one outting Brad |
At first I was going to Super Chevy ,but I will be out for your event. All leaks will be fixed and I know WHP will be looking at me closely
