Old 10-04-2019, 10:40 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1970 396-375HP Engine
1970 396 .030 over casting #3969854 dated H-20-9 with a CKO stamping on the front pad and is a 4 bolt 375HP engine. The block was cleaned, magged and pressure tested. Block had one hairline crack in cylinders #5 & #7 so they were fitted with sleeves. Block also has new cam bearings and freeze plugs installed and the walls are clean enough it might stay where it is at. I have the 11 to 1 pistons with dimple rods, 6223 steel crank .010 under, 3964291 heads dated F-6-9 & F-18-9 cleaned and magged with hardware to put back together, manley double roller timing chain, new high volume oil pump, PF 25 ac delco oil filter in the box and a set of ac delco spark plugs in the box for the engine as well.
Can ship if you cannot pick up and can provide pictures with a email address or phone number. I can be reached at 330-770-2517 for any questions.
$3250
dlv4540 is offline   Reply With Quote
