Liked 186 Times in 48 Posts
Hi. I plumbed a Line Lock like this (below). It seemed like a clean way to plumb it without using a "T" inline. This saved a couple of potential places to leak
![]() Thoughts? Wayne ![]() |
Liked 133 Times in 76 Posts
Pressure is pressure, doesn't matter if you had a T or used the LL body as the T, Once you activate the solenoid you pump the pedal and the LL is a one way check valve.
#3 | |
Wayne |
Liked 43 Times in 29 Posts
You may want to add a small rubber pad to insulate the line lock from the fender well. This way you eliminate or lessen any vibrations or stress on the lines.
Mark Ruset 2048 STK |
Mine is plumbed the same way. Working fine. Looks great!
Joe Martens AA/Stock 3969 |
