Liked 904 Times in 237 Posts
I am looking for a Racer who can look over my Generator and tune it up at The Bowling Green race this weekend. I am pitted facing the track Right where the fence ends for staging or my phone number call 602 284 6240
I think a person could make some money jut going around fixing the generators at the track call me
Don Kennedy 7701 SS |
Liked 226 Times in 137 Posts
Isn't Camping World right there?
I am looking for someone at the track My Generator keeps throwing a code .I know how to eliminate the code but need to fix the issue if it keeps doing whatever the code means the code is 27
Liked 9 Times in 6 Posts
Code 27 is a voltage sense fault meaning that the controll is not reconizing AC voltage being produced. Could be caused by bad brushes, bad wire or connection, A! controll or even the rotor or stator. ... I would start by inspecting the brushes. Problem Hope you find a Fixer
Liked 262 Times in 74 Posts
Newer Onan's had an issue with Broken brushes. Just helped a friend with that issue. They often break a brush and keep running for a while until the broken brush is no longer long enough to contact commutator, then throw a code and will start then shut off due to the lack of voltage. If you test the resistance of the wires from the brushes and it's an open circuit(infinite resistance) you have broken brushes. I'll have to look up the pin out for the connector. It's a bit of work to fix, but not complicated.
Steve Polhill 3520 STOCK, COMP Last edited by Steve Polhill; 08-22-2019 at 09:22 AM. |
Liked 557 Times in 217 Posts
What model/size is the machine you are having trouble with
Diesel or gas and what KW is it or Model Letter code off the machine's ID label....and how old is it and how many hours on it All this info is helpful and since I work on them constantly.....I can tell you a lot more once I know this info.... I am in NJ and yes I do work on machines when I'm at a race sometimes for racers or at least take a look....a repair could be much to difficult at the track......
