Old 07-21-2019, 12:58 PM   #1
Dale Hulquist
Liked 351 Times in 76 Posts
Default Questions on RacePak SC1000
On my new to me Cobalt, it has an older racepak SC1000 and we are unable to load the software (disc) is it possible that's because the racepak software is circa 1995 and the computer's aren't compatible ? Any advice would be helpful. Thanks Dale H
Dale Hulquist
4006 Stk
4006 S/Stk
Dale Hulquist is offline   Reply With Quote
Old 07-21-2019, 02:20 PM   #2
KRatcliff
Liked 534 Times in 143 Posts
Default Re: Questions on RacePak SC1000
"You need to hit the logging switch the moment you reach 88 MPH in order to get the 1995 version of the Race Pack to function properly."
M. McFly
KRatcliff is offline   Reply With Quote
Old 07-22-2019, 08:13 AM   #3
Rsmith38
Liked 28 Times in 15 Posts
Call RACEPAK and talk to Todd. I have the SC1000 and Racepak still has support for it.
Rsmith38 is offline   Reply With Quote
Old 07-22-2019, 10:44 AM   #4
Dale Hulquist
I will make that call today and ask for Todd, i was told by another racer that they no longer supported the SC1000. Thx
Dale Hulquist
4006 Stk
4006 S/Stk
Old 07-22-2019, 12:45 PM   #5
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
The latest version of the software can be downloaded. Does the software not work at all or are you unable to transfer a run? If its a transfer issue I might know what your problem is.
I just went through this when I got a new laptop with Windows 10 which is 64 bit. The SC1000 memory card is a 32 bit system and not compatible with newer 64 bit windows. Racepak will try to sell you a 64 bit memory card but its over $300. I'm going to put a logger dash in the car next year so I found a work around for now. I installed a virtual machine on my laptop and run a copy of 32 bit Windows XP just for the SC1000. Works perfectly. The virtual machine software can be found for free and an old copy of windows can be bought off ebay for $10.
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is offline   Reply With Quote
Old 07-23-2019, 09:01 AM   #6
Dale Hulquist
Thanks Troy, that's the problem were having it will not load on our newer computer I'm going to show this to my IT expert aka (girl friend) if it's ok I might have her pm you ? Thx
Dale Hulquist
4006 Stk
4006 S/Stk
Old 07-23-2019, 12:29 PM   #7
Troy Henderson
You bet.
Troy Henderson
