Old 07-09-2019, 10:45 PM   #1
Duster 7695
Liked 8 Times in 6 Posts
Default H/SA Dodge Aspen
Car is run as a '76 with a 360 factory rated at 175 hp and NHRA rated at 284 hp with the small cam. Runs .8 under in bracket mode. New engine by Mike Blackstone with Don Little heads. New Pro Trans with 23 runs on the new combo.
Car has 1 1/2 quart oil accumulator, MSD7al2 with 2 step and 3 step,Innovate A/F system,Aeromotive 2000 fuel system,ATI 8" converter,Mark Williams 4.86 and 5.13 third members,Calvert Suspension and shocks,Wilwood fronts and drum rear brakes.
Numerous spare parts including Moroso water pump,MSD pickup, 7 AL2 box,MSD tester,8"T/A converter,Shubeck lifters,rocker arms,3 ThermoQuads,5.13 gear set,etc worth over $5000.
Asking $19000. Will deliver.
Raul
rvargas4@cox.net or 480-748-0481
Duster 7695 is offline   Reply With Quote
Old 07-10-2019, 01:52 AM   #2
GTX JOHN
Default Re: H/SA Dodge Aspen
Raul: You forgot a 0.
Pretty sure you meant $19,000 and it
is worth every penny!
John Irving
741 Stock
741 Super Stock
Old 07-10-2019, 04:58 PM   #3
Duster 7695
Thanks John.
Raul
Old 09-01-2019, 05:32 PM   #4
mopacltd
Liked 124 Times in 44 Posts
Raul, I just can't believe your beautiful Duster hasn't sold.
mopacltd is offline   Reply With Quote
