BBC Parts 1965-1970
1965 396 4 bolt block dated E-27-5 with IE code casting 3855962
1969 3919840 square port heads dated J-30-8 & J-31-8 with new hardware to build.
1970 396 4 bolt engine CKO code standard bore casting 3969854 dated H-20-9 with 3964291 heads, 6223 crank, 11 to 1 pistons and rods, 8 inch harmonic balancer and some small parts if needed.
ZL1 aluminum tall deck Can Am and Yenko block 3946052 pressure tested and is a standard 4.40 bore.
Can ship if you cannot pick up and can be reached at 330-770-2517 for any questions or pictures needed. Best offer on parts
