Old 06-10-2019, 03:45 PM   #1
Kevin Panzino
Kevin Panzino's Avatar
Liked 778 Times in 142 Posts
Default Towing with older, low powered diesel pusher?
Have any folks on here tow, or used to tow with an older (mid 90's) diesel pusher that has a fraction of the power and torque of the newer MH's, or even our pickups actually ?
I found a good deal on a clean, nice little 1994, 30', 5.9 6BT Cummins/Allison pusher. It is only 210 HP, 475 FT*Lbs. It has a mechanical Bosch 'P' injection Pump, and I am very familiar with getting those up to way, way more power. BUT, it only has the AT-542 4-speed Allison, not the big 6 speed, and my reading on it, says it will not be happy with much over 275 HP/550 Ft*lbs.
So I was wondering if anyone had towed with a lower power pusher MH, just how painful is it?
My trailer is right around 9,000 Lbs loaded.
I don't have to go 75 MPH up long highway grades, but also don't want to be in the shoulder with the hazards on going 30MPH either.......
