Liked 562 Times in 139 Posts
Complete unassembled 360 super stock motor, Precision Cylinder Heads from Studley, fresh everything, Harland sharp shaft rocker setup, edelbrock intake matching the heads, these heads went 9.82 to set the record in Shane Studley’s Dakota, brand new cp pistons, with total seal ring setup, brand new no hole balance scat crank/rods, 72 360 block with tall fill, cleaned up just needs final machine work, everything I have plus spares
$15k Protrans 904 with converter, older pro trans but works great, 6200 stahl I believe, will not sell the trans until motor stuff sells $3500
Tim Stickles Last edited by tstickff; 06-07-2019 at 07:34 AM. Reason: please delete |
